Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC, Hyd Roller Question Please
Old 04-29-2010, 02:24 PM
Guy Hiltz's Avatar
Guy Hiltz Guy Hiltz is offline
You'll get an answer quicker if you post the cam specs;
http://www.compcams.com/Cam_Specs/Ca...?csid=435&sb=2
280 adv duration
224 dur @ 0.050
0.566 valve lift
110 LSA
Also posting your compression helps others with recommendations.
The carb may be a bit small,but otherwise you have a decent combo.Although big blocks respond well to bigger cams.Realistically,you might be in the 450-475 hp range.
Also,whats it going in ??
Guy
