ERICNOVE72, THANKS piston/cam stuff
crap..maybe if I did not Zero deck the block she would drop to
pump gas level using the L2349F60. This is what I was leading to
in other questions about the 496 stroker route. after a guy decks
the block, mills pistons etc..you are up at the cost of a SCAT stoker
kit. which I can get for $1700.
Or use the L2365F60 and rebuild my 049 heads????? Want to stick with
these 291's though becasue they are clean, with SS 2.19/1.88 rect port.
There has to be something out there that would yield a 9.8 or 10.1
for a piston in a .060 454 ???
Darn
Thanks
