Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC, Hyd Roller Question Please
Old 04-29-2010, 04:35 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Main problem you are fighting is the closed chamber, back when they were factory installing this head cheap high octane gas was in every station you stopped at.
I would want to stay with the 291 head also for the power they can produce, you are just going to have to work it a little to get a pump gas compatable ratio. It is still too high with the correct 2349 piston even with the undecked block, but the fix is easy, just machine the dome down. 1/2 hour job, shop shouldn't charge more than $50 to do this - if you or a buddy doesn't have the ability or the equipment (lathe or mill). This would be the route I would take.
The closed chamber head will present the same problems with compression ratio on a 496, maybe more so as virtually all stroker combo's are configured for the much more common(and aftermarket standard) open chamber.
The 2349 piston fix is real simple, even a caveman could do it. An ambitious and motivated person could even do it with a flat file and a buttload of time if they are mildly skilled with hand tools, a pair of calipers and pay attention to what they are doing.
