BBC Internal water leak???
Hey just built a 454 marine engine for a jet boat, the engine is cooled by water coming out of the jet drive, after about 1/2 hour of running, the oil on the dipsitck came out milky, the level did not go up tho????, just wondering if anyone has come across cracked blocks and possibly places to look for cracks in the block, thanks!
Right, while the engine is together right now, I might try pressuring the cooling system and locating the leak maybee something simple
A pressure test of cooling jackets could find a leak there, most often those type leaks are gaskets but sometimes casting cracks as well. Bogie |
Yeah I tested it tonight and the cooling system is ok there are no leaks, buy I do have a faulty intake restrictor valve thats letting full pressure and volume of water to my block and causing my water injected headers to come on at idle, causing inversion to my cyls, blowing by the pistons
| Internal vacuum leak from manifold on SBC? | kyle86 | Engine | 4 | 10-27-2010 11:15 PM |
| Engine water leak? | HotRodMan | Engine | 4 | 01-29-2009 05:31 PM |
| water leak?? | pi71 | Engine | 5 | 08-27-2007 07:38 PM |
| internal vacuum leak in sbc???? | Danscam | Engine | 9 | 06-16-2007 10:29 PM |
| Water Leak into Engine | MartinM | Engine | 8 | 10-31-2002 04:13 AM |
