Originally Posted by airboat
I built another set of Vortec L29 7400's for the 454 in my ski boat. It just had peanut ports with flat tops about .012" down the hole so I just did rings and bearings with a Comp 270S cam, Stock size Ferria valves and a composite head gasket. I added an Edelbrock Performer and the difference is amazing!! Killer top end!!!
People Have said putting the Vortecs on a Mark IV results in coolant leaks into the engine valley, Not so in this case..
GMPP has also warned of there being leakage from using Mark IV heads on a Gen 5:
Important Technical Note: Use of the adjustable Mark IV cylinder head is not recommended with the new “Gen V engine,” except with Bow Tie racing blocks and all Gen VI with six-bolt composite front covers. Changes in the configuration of the “Gen V’s” coolant transfer passages allows coolant to seep into the lifter valley when the Mark IV head is used.
Victor Reinz has designed two Nitroseal® head gaskets to specifically allow for this conversion.
The installation requires Victor Reinz part number 4918 be installed on the right cylinder bank to maintain proper coolant circulation, and part number 4923 to be installed on the left cylinder bank for the correct coolant flow.
