BBC MK VI and BBC MK IV Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2008, 08:07 PM
Mustangsaly's Avatar
will the older BBC Mark 4 GM 049 Heads work on the BBC Mark 6 Block ?
the mark 6 block is a newer vortec roller block correct ?
thanks
Old 02-22-2008, 08:14 PM
Yes the Mark VI is called Vortec and it does use roller lifters.Mixing old heads with these newer blocks is considered a risky proposition.Somewhere along the gasket less than a quarter of inch of mating surface seals water from oil.
Old 02-22-2008, 08:23 PM
is the MK V block a factory roller block ?
Thanks
Old 02-22-2008, 08:57 PM
Get the correct gasket from Fel Pro and it works fine.
