BBC motor mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2009, 09:06 PM
diamond mike's Avatar
throw me under the bus agian
BBC motor mounts
hey guys, whats up? well, my BB is in my stepside. sorta. is there anyway you can get the motor mounts put on the wrong way? like on the wrong sides? im just asking, cuzz it seems like no matter what i do, it wont line up, oh, the tranny is already bolted up, this is the same block that came out for the build. i just got in from working on it, so i figured id ask before tomorrow ( round 2 )
Old 10-23-2009, 09:14 PM
ericnova72's Avatar
More for Less Racer
No left or right to the "clamshell" mounts on the block, but if the rubber is wore out in the rubber-encapsulated frame side mount it can give you problems with alignment.
Old 10-23-2009, 09:19 PM
right on, at least i know thats not the problem, makes me feel a little better, mike
Old 10-24-2009, 07:48 AM
6426yy's Avatar
The haynes manual shows two different mounts, but I just replaced the 350 in my 83 P/U with a 454 and it went right in. The last time I did this swap, I bought the "BB" mounts thinking they were different but It appears the stock ones work.
Old 10-24-2009, 08:43 AM
Have you slid the transmission back as far as possible? Loosen but don't remove the transmission to crossmember fastener, and slide it back towards the bed. Should provide some additional clearance.
Old 10-24-2009, 04:18 PM
bingo
yea yea! went in, finnally! just needed some persuasion with the breaker bar! i just had to wedge it in between the front cross member and the front of the engine, and push , and bam! it walked itself in. well, now the buttoning up has started, mike
BBC MK VI and BBC MK IV Heads Mustangsaly Engine 3 02-22-2008 07:57 PM
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
BBC stroker firestone Engine 0 03-20-2006 06:29 PM
96 to 00 BBC Question Mustangsaly Engine 6 02-20-2006 07:03 PM
BBC Big Block Questions Mustangsaly Engine 6 01-21-2006 06:59 PM
