Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bbc new stock cam, misfire, backfire; timing?
Old 03-10-2011, 05:21 PM
oldhickory oldhickory is offline
Originally Posted by eloc431962
I would say your are simply out of time .IMHO Go back and pull the #1 plug and bring it back up and see where it's at from there. see if it's at #1 on the distributor or not. JMO Take a breather and don't get overwhelmed.
i did as you suggested. (took a breather.) lol. then i pulled the number 1 plug. i plugged the hole with my finger and turned the crank until no more air could be heard hissing out between my finger and the block. the timing mark was actually at 10 degrees btdc. (should air be coming out all the way to 0 degrees tdc?) then i pulled the dist. cap and the rotor is pretty close to the number 1.
