Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bbc new stock cam, misfire, backfire; timing?
Old 03-10-2011, 06:03 PM
oldhickory oldhickory is offline
ok. thanks to Rineholio i got things semi-straightened out. i put the crank to 10 degrees tdc on compression, then i set the rotor to point straight to the number 1 post on the cap. its not backfiring anymore. got kinda hot tho. 225. gonna check coolant after she cools off.
