bbc new stock cam, misfire, backfire; timing? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-11-2011, 08:39 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by adantessr
Most likely after setting the timing at 12 deg static with a timing light the overheating problem will be gone. Timing just a little retarded will make an engine run hot .
X2 tweek the timing should cool it down.
Glad you are getting it figured out.
Cole
no power/backfire through carb/timing? 355 build Muttstang89 Engine 23 11-23-2010 07:35 AM
350/305? timing backfire/carb-what do I check next 1960chevyapache Engine 29 07-24-2010 06:31 PM
Stock 96 Vortec timing 41'srfun Engine 1 05-04-2010 08:53 AM
backfire on stock 350. pittbull7934 Engine 11 06-21-2009 08:56 PM
Timing? or Carb? causing backfire 5.0Falcon Engine 8 03-22-2005 11:12 PM
