bbc new stock cam, misfire, backfire; timing?
i just installed a new stock cam in my 402 bbc. i also put in a new timing chain and gears. the truck starts and throttle response is pretty good, but it sounds like its missing on one cylinder and occasionally backfires. it has backfired at the carb and at the muffler. when i installed the sprockets for the timing chain, i had the engine at TDC on compression stroke. the dots on the gears were both at 12 o'clock. i pulled the gears off and installed the new ones the same way. i used a straight edge to make sure they were aligned. i have not let it idle but i have started and stopped it a few times. i have checked and rechecked my plug wires. i have a couple of questions:
first, is it possible that i am a tooth off on the timing chain? would that cause a misfire? second, should i break the cam in with the engine misfiring, or should i address that issue first? |
Did you verify and turn the crank one full revolution as it will put the cam dot at 6:00 and the crank dot back at 12:00 to know fore sure it is in alignment (TIMING GEARS)? If so then you need to just rotate the crank one more full turn placing the cam dot and crank dot both back at 12:00 and you can set in the distributor pointed to the #1 post on the cap.
Should be right there and be in time. Cole |
If you put the cam in correctly then I think your distributor is off a tooth, making your timing way off. Have you checked the timing? Put #1 at TDC. Make sure it's on the compression stroke. See where the rotor is pointing. I wouldn't fire it up to check the timing until you do that.
I'd also recheck the plug wires once more. Maybe one is swapped. The backfire makes me think it has something to do with ignition. |
no i did not. i wish i had tho. if i was off by a tooth would that cause my problem?
You can use a timing light on it at 2000 or 2500 rpm . It doesn't have to be at idle to check the timing.
Cole |
As long as you were varying your engine speed from 2000-2500 when you first fired it up, and kept it there until you shut down and didn't do a bunch of idling, your cam will be fine. When you fire it up next time, just run it to 2000-2500 again and you'll be fine. Make sure you have cam break-in supplement added to your oil though.
My buddies and I have been building engines, racing, and swapping cams in cars and motorcycles since the mid 70's. We've had to stop break-in several times for things like an angry psycho neighbor (open headers in town not popular), police (open headers again), overheating (not my car), and an oil leak (not my build). As long as you shut it down without idling much and you restart with normal cam break-in procedures, you'll be fine. I wouldn't be real comfortable doing it with a solid flat-tappet with .630 lift and springs to match. I have no idea where all this cam break-in paranoia comes from, especially with a stock profiled cam and matching valve springs. A lobe will not flat because it turned over 300 times between the time you let it idle down and then shut off the engine. Flat tappet cams were used for maybe 100 years before the big three ever even invented roller tappets. Stop worrying about your timing chain-for now. If you used a straight edge to check it you're probably just psyching yourself out. Check the distributor and if that's good come back to the forum. It'll take 10 minutes. It's hard to give you advice unless you tell us how you started it, how long you ran it, what rpms, and did it run fine at first and then start running bad, or was it the same the whole time. I'll PM you my phone number. |
ok. thanks to Rineholio i got things semi-straightened out. i put the crank to 10 degrees tdc on compression, then i set the rotor to point straight to the number 1 post on the cap. its not backfiring anymore. got kinda hot tho. 225. gonna check coolant after she cools off.
Most likely after setting the timing at 12 deg static with a timing light the overheating problem will be gone. Timing just a little retarded will make an engine run hot .
| All times are GMT -6. The time now is 08:37 PM. |
