BBC non adjustable valves.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2007, 08:47 AM
I need the torque to install the valve stud for a BBC 454 non adjustable hydraulic lifter. Does the valve have to be open or closed or does it make any difference. One came loose and I am going to replace it. Thanks for any suggestions...
Old 04-30-2007, 08:58 AM
Jmark's Avatar
I found your torque specs Here.............
Use some kind of thread sealant or RTV on the rocker stud threads and torque to 50 pounds.
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
Adjusting Valves and Fuel Pump Install demitristewart Engine 5 08-09-2006 10:10 AM
bent valves inquiring_mind2 Engine 34 07-16-2006 10:20 PM
BBC street/strip valves (PAW???) deuce_454 Engine 2 04-26-2004 05:03 PM
BBC Heads, Valves size, harden seats ??? Impala5967 Engine 1 10-01-2003 08:27 PM
