BBC oil capacity - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2005, 08:57 PM
FiveFeezy's Avatar
Fishing poles in the hot rod!
BBC oil capacity
I always thought a stock BBC oil pan held 5 quarts. I looked it up in the manual and its says 4 quarts. But on my dipstick it shows that I am a quart short. Which one is right?
Old 09-06-2005, 09:41 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
I think what you are seeing is, in fact a five quart system. That means 4 quart pan, 1 quart filter for 5 total quarts. I would not imagine that a BB is a 4 quart system.
Old 09-07-2005, 08:53 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
it depends if you have a high-capacity oil pan.
but stock bbcs, I honestly dont know. I'd read the above post, he's prolly got more experience than I do.
Old 09-07-2005, 02:45 PM
larryblack's Avatar
Certified Lead Foot
My 396 took 4.5 qts with the short filter. I have done 4.5 qts in 427's and 454's with stock pans and short filter. Using the long filter usually made it a full 5 quart. I did one LS6 Chevelle that was 5 qts with filter.
Most guides are per GM specs and GM specs show the PAN capacity. The next statement usually noted how much oil would be needed with a filter change.
Once upon a long time ago, folks would change the oil but not the filter. Some older engines did not even have filters. It took until the mid 70's before the actual oil pan and filter capacities became the norm in manuals.
I have seen some recent books still using the 50 year old instructions.
Old 09-07-2005, 07:08 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Do you have a stock GM dipstick and tube. Cheap chrome aftermarket dipsticks are rarely accurate.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 01:51 PM
BBC, no oil pressure mackyLS6 Engine 5 08-23-2004 09:23 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
