Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC oil pump question
Old 07-11-2012, 01:01 PM
Cridder's Avatar
Cridder Cridder is offline
Last journal entry: 310 Small Block Chevy
Originally Posted by S10 Racer View Post
No need for a high pressure spring. You don't want excessive pressure. Std. BBC pump is all you need.
Ignore this advice and install the blue spring that comes with the pump,
Cruzing pressure on my 357 small block with 15-40 oil sits at 58psi, (by no means excessive) about 10 psi less at idle, I lug it in my 4x pretty hard at times. cheap insurance imo.
