Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC oil pump question
Old 07-11-2012, 04:14 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by Cridder View Post
Ignore this advice and install the blue spring that comes with the pump,
Cruzing pressure on my 357 small block with 15-40 oil sits at 58psi, (by no means excessive) about 10 psi less at idle, I lug it in my 4x pretty hard at times. cheap insurance imo.
Dude, he is not building a Top Fuel engine which operates at 200psi oil pressure. He is building a street motor with occasional track time. There is no need for anything above 20-30 @ idle and 40-50 psi @ cruising speed. A stock pump will get these numbers if all the bearing clearances are right. Your idea of more pressure is "cheap insurance" makes no sense.
