BBC piston I.D. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2014, 10:16 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
BBC piston I.D.
These pistons are in a new to me 496 BBC, they are JE Forgings, and the only identifying numbers are the forging blank number, JE and 735S. Believe me, I've been all over the pistons, there is no p/n or job number. I know JE says they all have it, but not these. The only thing I haven't done is pull a piston and measure the compression height, so I have no idea what the rod length is either.
Tough call, but can anyone identify these, give me the dome volume? This is a tall deck motor, the piston is 4.310" and the dome is .30" tall. I've been all over JE's web site for help.
ID:	151930   Click image for larger version
ID:	151938   Click image for larger version
Semper Fi
Old 06-07-2014, 10:43 PM
ericnova72's Avatar
More for Less Racer
I can't remember if it was JE or SRP or Wiseco or Ross, but sometimes you will find job or part number on the outside of piston, in the relieved side area that is at the pin bore area of the piston...but you have to remove one to see it.
Can't help you more, for some reason JE's web site won't even open for me Google says it can't find it??
The domed off the shelf JE piston list at Flatlander Racing in that bore and stroke the two(different rod lengths) listed pistons were 43cc and 44cc dome versions....but that doesn't cover custom pistons, and unfortunately didn't give dome height like it does for Speed-Pro/TRW and Icon pistons.
Old 06-08-2014, 01:14 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I appreciate your help Eric. I've been all over JE's site earlier, didn't find anything helpful. I'm unable to access it now either.
I went and pulled a piston, there is absolutely nothing anywhere inside, outside or on the top. I'm pretty good at math, but can't think of a way to measure the volume of that dome, must be an age thing... I have 23 cc dish pistons in the blower motor, this dome, to me, doesn't look like 43 cc in comparison.
Not that it matters, but the previous owner claimed approximately 10.5:1, if that's a 43 cc dome, that brings it up into the 13:1 range. Here are a few more pictures, poor quality up close. Maybe someone out there has this piston and knows the spec.
BTW, the rods are 6.535, compression distance is 1.52 as close as I can measure, again, this is a tall deck block.
ID:	152154   Click image for larger version
ID:	152162   Click image for larger version
ID:	152170   Click image for larger version
ID:	152178   Click image for larger version
Semper Fi
Old 06-08-2014, 09:07 AM
BOBCRMAN@aol.com's Avatar
Looks like the domes were cut down for compression reasons. I have several sets cut like that. Thats why no part number. It went into the chip tray..
Depending on the head chamber cc. and stroke, they look like around 10.5 with a 119 cc head. Compare the dome with a Probe, Icon, Keith Black. You know the rod length..Pin height will give you the stroke they were intended for.
Old 06-08-2014, 09:39 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Very possible Bob. I could calculate (with a dome height of .3"), the total volume of a cyl, in cc, what the dome height is, 4.310 bore.
Then put the piston down, top of the dome flush with the deck, seal it with Vaseline, cc it and do the math, the block is zero decked.
With moving coming up in two weeks, I've packed all my manuals and catalogs already, when I get set in the new shop I should be able to do better research. I'm like a dog with a bone now.
Thing is I've seen pictures online of that dome shape, in another piston, but no dome height listed, not that it would be the same...
Semper Fi
Old 06-08-2014, 04:29 PM
ericnova72's Avatar
More for Less Racer
You're thinking what I was going to suggest next, the down the bore volume check.
Bob is most probably correct, that it's an off the shelf big dome piston modified by previous builder to a new lower compression ratio. At .300" tall and about 1/2 bore diameter, you're in the low 30's for dome cc as just a quick rough estimate.
BBC Piston I. D. 68NovaSS Engine 3 03-01-2013 08:17 PM
BBC Piston Part#? Jimster1973 Engine 2 10-21-2008 12:24 AM
BBC piston question 1969NovaSS Engine 2 06-28-2006 09:54 AM
bbc piston question 1969NovaSS Engine 3 03-10-2006 05:55 AM
bbc piston problem import_crusher Engine 28 01-16-2006 11:30 AM
