BBC Piston Part#? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 09:24 PM
BBC Piston Part#?
Hi all, I need some help, I have a 1974 BBC Block #3999289, Crank #7416,
Head #336781. Piston #340204-Z17. Can anyone tell me what kind of pistons are these? That is the only # I can find on them. I can not find this number anywhere. Thanks for the help...
Old 10-20-2008, 10:42 PM
May be of help
I'm not sure what the Z17 designation is here. As for the 340204 designation?
340204 is a GM O.E. casting number. This piston was produced for the 454 (7.4L) Chevy engine but for the years 1981-1990. Apparently your 1974 has been rebuilt. The specs are as follows:
Hypereutectic, destroked .020". Trucks 2.00" dia. head recessed. .085" deep two valve reliefs. These pistons are sized from std. through 0.060 oversize. Hope that helps.
Old 10-20-2008, 11:24 PM
Piston #
Thanks, That helps a lot. Are the 340204 pistons any good? I want to try and get close to 500 HP from this motor, What would be a good piston for this? I will not be useing nitrous or anything like that. Just a Holly 850.
The motor is STD bore. Thanks.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Flathead Piston ???s for you guys danker1960 Engine 0 06-07-2006 07:44 PM
i need a piston ring part number. 98 350 vortec 406 ss monte Engine 3 06-03-2006 10:22 PM
Piston ring Question (For Nitrous) Ratoflic Engine 0 04-19-2006 04:04 PM
bbc piston question 1969NovaSS Engine 3 03-10-2006 04:55 AM
