bbc power? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2009, 10:35 AM
bbc power?
im building a 489 with 10:1 comp with ported merlin heads and a mildish cam upper 230's duration, close to 600 lift, anyone have a ballpark what kind of power itll make through a th400 and tune semi aggresively on 93oct, just curious
Old 05-23-2009, 12:00 PM
firestone's Avatar
http://teamrfc.gospelcom.net
Do you have the full cam specs? Assuming you will have a good exhaust system, I bet you will be around 575hp and 600 ftlbs. That is assuming a hydraulic flat tappet cam with mid .500 lift. If you got a cam with .600+ lift, I think as much as ~650 hp may be possible. I think the motor below is a good one to compare to.
I am pretty sure I found the cam for the engine below:
236 246 @.050 .553 .571 lift
540 hp 509:
http://www.jegs.com/i/World+Products...8000/10002/-1#
Ill bet The cam is very close to yours. This engine has a little less compression and the heads are not ported.
Adam
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 10:09 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
