Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC push rod mystery
Old 05-02-2013, 05:23 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Whoever you talked to at Comp Cams should be fired..
Big blocks have used 5/16 pushrods since the early seventies. In base engines and truck engines. Most common pushrod you will find in a stock 454.
Buy some 3/8 guide plates and you will be running again..
