Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC push rod mystery
Old 05-11-2013, 02:27 PM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is online now
Built Not Bought
Last journal entry: 53 ad3100
Since all big block chevys use guide plates pushrods from CC should be hardened ,,USE an adjustable pushrod length checker to make sure you have right length, I used Comp cam ,lifters push rods valve springs.,roller rockers,timing chain and gears,,the pushrods were to short I had to order 125 th longer on intake and 250 th longer on exaust ,the ones that came with cam kit would not work the rubbed my guide plates had tp grind small amount with die grinder then reinstall until I got the clearance I needed,
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
Bobbity (05-11-2013)
