Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC push rod mystery
Old 05-16-2013, 09:25 AM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is offline
Built Not Bought
Last journal entry: 53 ad3100
Sorry to hear bad luck, I have good luck with summit shipping,your falcon is looking good you are moving fast ,on the cam I ordered short duration for low end torque since I am running 496 cu in it takes lots of air 225-188 valves 113 cc heads I needed extra lift a 331 rear gear 29in tires .probably will never turn it over 6000 any way reve limiter set at 6 k, if I turn it to 6 it should drop to around 45 on shift that will keep it in power band ,I will run the clock once to get a et,then it will be street driven after that.
