BBC questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 08:47 PM
BBC questions
OK lets try this again without the input of judgmental people,
i know the generation of my block i think ...gen
what is the oil capasity of a stock 454 oil pan?
Old 02-18-2009, 09:01 PM
depends on the stock application
Old 02-19-2009, 02:02 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
There were several setups. For the most part, early car pans were 5qt and trucks were 6 qt. Those numbers are total capacity with filter. Later on, most car chassis would accept the truck pan, so they were used in cars as well.
There are also three basic sizes of BBC filters. There is the car type which is only about 4" deep, the normal truck filter which is about 6" deep, and another HD filter which is about 9" deep. Combinations of stock pans and filters can yield anywhere from 4.5 qts up to 8 qts.
Its really not a big issue. The easiest way to determine your combo's capacity is to do an oil change. You can rest assured that it will take at least 5 qts. Put 5 qts in and check the dipstick. Keep adding oil until you reach the max line on the dipstick. Then start it, let it run for 30 seconds or so to make sure the filter is filled. Recheck the dipstick and fill it to the "full" line. End of story.
Old 02-19-2009, 10:35 AM
i was wondering because im building a 496 and i have the stock oil pil and was thinking i should step up the amount of oil in the engine and i didnt know if i should look for a 6 or 7 quarts....is it necessary to increase the amount of oil if i go to a 496?
Old 02-19-2009, 12:42 PM
It all depends what are you building it for. Seven quarts sounds about right depending what size oil filter and oil cooling lines are in the set up.
Old 02-19-2009, 03:58 PM
curtis73's Avatar
Wiki Edits: 16
I built a 468 with a stock pan, revved to 5700. Nothing too special, but I never needed any more oil. The truck pan works fine, but it does hang down about 1/4" lower than most crossmembers, so if you bottom out the pan gets it first.
Old 02-19-2009, 09:15 PM
My 78 truck 454 holds 7 quarts.... if that helps any.
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 12:44 AM
Going from BBC back to SBC(2) will have questions... Bumpstick Engine 4 09-20-2005 09:15 AM
ANSWERS TO COMMON QUESTIONS -- PLEASE READ BEFORE POSTING Jon Hotrodders Site Suggestions and Help 0 07-07-2005 03:58 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 03:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
