S-10, all cam roller bearings I'm aware of are race only and aftermarket, you think GM ever put them in their OEM roller motors?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
To begin with, set the timing curve up correctly. Info here.
Once the timing curve is set up right, see if the carb problem has gone away or is much better. Knowing the cam specs will help. Short of pulling the cam or timing cover to get the numbers off the cam, you can find the specs close enough for tuning by following the info here. Good luck. |
| Bottom end? | against all odds | Hotrodding Basics | 3 | 03-21-2012 02:35 PM |
| BBC 049 Heads on 489-496 BBC with ISKY238/248 upper HYD roller cam kit | Impala5967 | Engine | 3 | 11-14-2011 09:05 AM |
| high perf solid roller valve train in stall on stock bottom end??? | Fbody5.7BIRD | Hotrodders' Lounge | 1 | 08-30-2009 06:45 PM |
| max rpm for a stock bottom end bbc? | chevelle4542speed | Engine | 8 | 10-29-2006 06:59 PM |
| how do I balance the bottom of this BBC | bigwildgrin | Engine | 6 | 03-07-2006 04:08 PM |
