Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC Solid mechanical roller or solid mechanical flat tappit???
Old 08-07-2010, 01:22 AM
ZAPPER68 ZAPPER68 is offline
Originally Posted by Hacksaw
Building a 489 stroker engine for street use. It will see time on the strip, and will only be a weekend cruiser. Trying to decide on a cam. Which set up would hold up better> Mechanical roller or mechanical flat tappit? If I go flat tappit, I will be using the lifters with the small holes in the tappit face. Anyway, which one??? Thanks
IMHO...if you want to eliminate all your worries about breaking in the cam...go with a roller. The controversy regarding flat tappet cams going flat has gone on for years. I had the front 4 lobes on my L72 427 go flat after I took all the precautions such as removing the inner springs, putting in oil addative, starting immediately etc. Good luck.
ZAPPER
