ZAPPER |
I won't run a flat tappet in anything of mine anymore.
If you decide to go with the solid roller cam,I would recommend the Isky EZ Roll lifters.These dont have needle bearings,they use a bushing,so theres no worry about needle bearings flying apart.
Guy |
I worry about running a solid roller on the street. I have been told that in racing apps the mechanical roller stuff lives in a world of low rpms and high rpms. Fast acceleration, and stoping. This driving gives the lifter plenty of oil. I was told that using a mechaincal roller on the street at constant rpms would starve the lifters/cam of oil and cause problems. True or false???
A lot of the solid rollers now have a direct oiling of the rollers so they should stay lubricated. I have some Howard's lifters in a box with this so I don't know if they actually last longer.
Guy |
I ran a solid roller in my 427 for years on the street, it was a Herbert roller, .638/.657 lift, with Norris stainless roller rockers, Bo Laws push rods, and Crane stud girdles. Never had a minutes trouble out of the valve train, checked the adjustment about every 3 months, and SELDOM had to adjust ANYTHING, and even then, only a thousandth or two. That motor saw 7500 on a regular basis, and 8000+ on occasion. The 360ci. SBC I'm building now for my daily driver S10 is getting a mild Comp solid roller too, .525/.525, 224/224@.050.
Sounds like a roller set up is the way to go then. I've never ran roller stuff before. I'd be putting this in a non roller gen v 454 block. This was a 94 model engine and had a hyd flat tappet from the factory. Every other aspect of installing a cam is the same on this engine except for the timing cover being designed for a one piece oil pan gasket. What do I need to look for in the aftermarket to solve this. I believe a double roller timing chain will fit, I just don't know if it will be strong enough for a cam button? A ihra pro mod guy here in my home town said thy used to weld a socket on the back of the water pump to add support on the timing cover to keep it from flexing...poor mans trick I guess. He said it works...
Sometimes it's as simple as brazing a flat piece of sheet metal inside the timing cover for reinforcement,
Stud girdles are ALWAYS a good idea in my book, but not really necessary for a motor like you're talking about. I really liked the Herbert cam. At the time, I talked to all the major, (and some less well known) cam makers, and they were ALL trying to talk me into a smaller roller than the flat tappet I had to begin with. That was NOT what I had in mind when I decided to go roller. I approached them all by telling them the specs on the flat tappet I was currently running, and where I wanted to go with the roller, and they all tried to talk me into going smaller, except Herbert. When I told them what I was running, and that I wanted to go with a little more duration and as much more lift as I could get, they suggested a grind number, and the specs were pretty much exactly what I had in the back of my mind, so I ordered it. I was using a set of "good used" roller lifters acquired from a friend, and one of them went bad, taking out a cam lobe with it. Herbert repaired the cam like BRAND NEW for $75 (if I didn't know better, I would have SWORN it WAS brand new), and sold me a new set of roller lifters for like $175, I was so happy with their prices and service, I also ordered new springs, retainers and locks from them as well.
Not right now, I seldom buy new stuff cuz I'm too cheap,
I got a really good deal on a solid roller with the right specs for the race car, it's a Crower, I've had the mild Comp roller for about 10 years, just never had anything it would be right for till now. I had planned to go hydraulic roller on that motor, but almost $400 for the cam alone cured me of that idea pretty quickly. I do know a few guys running Herbert stuff though, and they are pretty happy with it. Chet is the father, Doug is the son. I think the son branched out more into all kinds of parts sales, where Chet stuck mostly to valve train components.
| Herbert Total Pro Series solid roller lifter | Fast1982 | Engine | 1 | 07-15-2009 03:38 PM |
| Solid roller to hydraulic roller cam questions | Hoonbash | Engine | 1 | 03-23-2009 07:06 PM |
| Comp Cams hydraulic roller vs. solid flat tappet comparison | Mad Maggot | Engine | 23 | 02-13-2005 10:29 AM |
| What is the BIG difference between flat tappit and roller cams | ozzt | Engine | 4 | 01-27-2005 08:06 PM |
| Roller or flat? When is a roller needed? | killerformula | Engine | 3 | 11-10-2003 03:58 PM |
