-   -   BBC Starter problem (http://www.hotrodders.com/forum/bbc-starter-problem-200276.html)
Ratoflic 06-13-2011 11:24 AM
BBC Starter problem
One of my friend have a BBC and have a starter problem.
With the old block (454) with the same starter and Flexplate the car start really fine, no trouble at all....we put the same starter/flexplate on the new block...and the trouble begin.....we had to change the flexplate..because the teeth was damaged...the starter bendix seem to not touch really the flywheel tooth......so everything is always broken..
Does somebody can help us.....
PS, this car have 12.5 CR and around 650hp...
Thanks, Stephane
troy norrad 06-30-2011 04:18 PM
Better start counting teeth on old flexplate and see if the same number comes up ?
Ratoflic 07-04-2011 07:46 AM
Hi Troy,
That's a 168 tooth, the starter is a 153/168 tooth...that's the same flexplate :(
eloc431962 07-04-2011 08:56 AM
X2 re-count the teeth and get the correct starter to match. :thumbup:
Cole
