BBC Starter problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 11:24 AM
Ratoflic's Avatar
Big cubic inches small Chevy!
BBC Starter problem
One of my friend have a BBC and have a starter problem.
With the old block (454) with the same starter and Flexplate the car start really fine, no trouble at all....we put the same starter/flexplate on the new block...and the trouble begin.....we had to change the flexplate..because the teeth was damaged...the starter bendix seem to not touch really the flywheel tooth......so everything is always broken..
Does somebody can help us.....
PS, this car have 12.5 CR and around 650hp...
Thanks, Stephane
Chevy man forever!
Old 06-30-2011, 04:18 PM
Better start counting teeth on old flexplate and see if the same number comes up ?
Old 07-04-2011, 07:46 AM
Ratoflic's Avatar
Hi Troy,
That's a 168 tooth, the starter is a 153/168 tooth...that's the same flexplate
Chevy man forever!
Old 07-04-2011, 08:56 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 re-count the teeth and get the correct starter to match.
Cole
454 starter problem barndweller Engine 8 05-25-2010 02:31 AM
Starter Problem 59chevywings Electrical 6 10-27-2009 07:46 AM
yet another gmc starter problem Rwolff Engine 4 10-12-2004 02:40 AM
starter problem ? timing problem? 6speedwagon Engine 1 08-11-2004 12:37 PM
starter problem 450hp67SS Engine 4 08-16-2002 04:05 AM
