bbc stock con rods vs aftermaket - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2009, 10:02 PM
i was thinking instead of spending the money of getting a new set of rods to just recondition the old ones by polishing and balancing them and sending them off to get shot peened. is my money better spent getting eagle h beam rods or reconditioning the old rods? this motor may see 7000 rpm occasionally but not often. i doubt it will ever see the track. its a 454cid bbc 2 bolt main. standard deck height. i just want a b.a street motor that will take some abuse and stay together. im looking for 5-600 hp and about the same in torque.
Old 02-23-2009, 10:10 PM
I think the stock rods will serve you well after you polish, shot peen, have them resized and add some ARP bolts.
Old 02-23-2009, 11:14 PM
What does it cost to have this stuff done? What does resizing do, and whats the benefit of polishing the rods? I cant see why anyone would want to polish something inside an engine just for looks...so there must be another reason.
Old 02-23-2009, 11:34 PM
first you grind off casting irregularities then polish it. gets rid of extra weight. what else can you have done to your rods to make them stronger?
Old 02-23-2009, 11:57 PM
You could upgrade to some L88 or LS6 7/16" dimple rods!
Old 02-24-2009, 12:55 AM
ericnova72's Avatar
More for Less Racer
For the cost of the total rework described you could get the Scat I-beam 4340 rods and have a much stronger piece. The H-beam wouldn't be necessary unless you were going to try for 8500 rpm.
Reworking a stock rod just isn't cost effective any more, aftermarket is stronger for the same dollars spent.
Old 02-24-2009, 04:59 AM
Last journal entry: PICTURE TEST
rods
First think about what you would spend on the stock GM rods, They will need new bolts,resized,plus the work you talked about.
Then price the scat I beams.
Something else to consider is that you can get the scat's with floated small ends for just a few $$ more.
I put the scats in all my customers engines over re-working the stock rods.
stock crank and rods nova33 Engine 2 08-21-2003 09:35 PM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
how much will stock rods and crank take? nastynova Engine 7 12-30-2002 05:03 PM
longer rods in a stock 302 mustang66maniac Engine 0 12-13-2002 02:08 PM
Forged Rods and Pistons for Ford 302? Mustang 69 Chile Engine 6 10-21-2002 06:39 PM
