BBC stumble on part half throttle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2010, 04:00 PM
diamond mike's Avatar
throw me under the bus agian
so now that i got my heads figured out, my next problem ....right now i got a 850 eddy matching intake, 60 over 454. its almost 100% tuned right, ( timing ect. ) the problem im having is in the dist. the weights to be more specific ( i think ) its a msd cap rotor and coil, accel weights, and springs. i think i got it too far advanced, too light of springs to be exact. ( making the advance too quickly ) when i really romp on it , it takes a moment to "catch up" kinda sputters, then screams. now, i haven't had this carb apart either, as far as i know, its all stock. the motor do sent ping or anything. could it possibly be getting too much fuel dumped in it to fast? causing the sputter? right now its 15 initial degrees, plus the weight which are smaller than stock, one black spring, ( heavier ) one white spring , ( one step below black ) im leaning towards to much carb, but id love opinions , mike
Old 04-07-2010, 06:37 PM
ericnova72's Avatar
More for Less Racer
It's not getting enough fuel dumped in fast enough when you hit the throttle, that is a lean sputter you have, not rich. It needs to have a bigger accelerator pump shot to "cover" this lean sputter. Go bigger on the pump adjustment, and you may need to change tha accelerator pump nozzle to a larger size too if just the adjustment doesn't fix it.
Very common problem with a modified engine. This is why there are tuning adjustments and tuning parts for carbs, they are never perfect for each person right out of the box, they are just baseline set to get you up and running so you can tune it.
Old 04-07-2010, 07:08 PM
damn it didnt cross my mind its not getting enough fuel, i totally figured it was flooding it, i guess i never have owned a built BB either though. thanks for the reply, mike
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Resin Casting ckucia Body - Exterior 9 02-12-2005 06:01 PM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 07:27 PM
Hesitation slightly over half throttle. Rubberman2003 Engine 3 12-11-2003 12:39 PM
