BBC swap?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 05:41 AM
BBC swap??
Could someone give me a list as to what I will have to change to put a 454 BBC in my 71 c10 350/350 turbo? I have heard a ton of things will work/wont work things like my radiator,mtr mounts,ect...Thanks
Any do's and dont's you guys know let me have em!!
Old 03-04-2012, 07:56 AM
bigtread's Avatar
I swapped a 454 into my 86 chevy truck and the only thing I had issues with was the power steering pump.
How complete is the BBC, did it come with all the stock bracketry for alt. , power steering. if it does not come with a flywheel you will need one of these as it is externally balanced.
Motor mounts are the same but I did install new solid mounts for my application.
and of course your exhaust will change a little due to bigger motor.
It sure is nice to have all those cubes under the hood.
456 gear swap to 373 in 8.5 rearend, carrier swap? leslie61 Transmission - Rearend 3 07-19-2009 03:45 PM
Tranny swap/ rearend swap? aggar Transmission - Rearend 2 03-16-2008 03:07 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 01:21 PM
Vin swap - firewall swap KenCam Hotrodding Basics 19 02-22-2007 10:44 AM
to swap or not to swap? 78 Nova for a 75 wayfast77 General Rodding Tech 3 01-26-2007 06:33 AM
