Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bbc Tall Deck Block 366 Question
  #16 (permalink)
Old 08-13-2012, 08:20 PM
rogernorton84 rogernorton84 is offline
ok bro iv got the same engine in a camaro one bad mother this is what to do about the square intake 'buy a square type of spacers one set of square port gasket and one set of large oval small tube of black gasket maker now put the oval on then a small layer of gasket then the spacers and finally the square gasket tightendown the intake run intill engine get warm retighten the bolts from center out ward remember u can put square on oval but not oval on square dont let anyone put down your 366 because iv won a camaro and a mustang and mine just has a points dis and a cam Qjet that spins threw 4th with 22 slicks good luck
