Bbc Tall Deck Block 366 Question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-13-2012, 09:20 PM
ok bro iv got the same engine in a camaro one bad mother this is what to do about the square intake 'buy a square type of spacers one set of square port gasket and one set of large oval small tube of black gasket maker now put the oval on then a small layer of gasket then the spacers and finally the square gasket tightendown the intake run intill engine get warm retighten the bolts from center out ward remember u can put square on oval but not oval on square dont let anyone put down your 366 because iv won a camaro and a mustang and mine just has a points dis and a cam Qjet that spins threw 4th with 22 slicks good luck
  #17 (permalink)
Old 10-14-2014, 10:02 AM
Holy thread resurrection Batman......so full of fail I had to.
  #18 (permalink)
Old 10-14-2014, 12:02 PM
vinniekq2's Avatar
welcome to the forum roller. not worth bringing up old threads like this,,,, start your own? what do you have for wheels?
  #19 (permalink)
Old 10-16-2014, 11:03 AM
So full of fail, the tall deck 366 and tall deck 427 were available in medium duty trucks until 1998.
It was replacfed by the medium duty L21 Vortec 454 with 8 coild packs, electronic throttle control and dual 80 pin 512 kb PCM. Its a Vortec 454 with a 24x reluctor. Electronically it thinks its a Vette LS1.
The L21 was available from 1998-2000 for teh most part, it was the 1st GM engine to get 8 coils and ETC. Not to be confused with the 1996-2000 Vortec 454 rpo L29 which came in 3/4 ton and 1 ton GMT 400 style trucks. It uses the 4 x reluctor ,"black box" PCM's, and Vortec style flat crab distributer/cam position sensor combo.
The L21 cam in heavier medium duty motorhomes and cab and chassis etc.
L21 Applications:
19982001 Chevrolet Kodiak/GMC TopKick/Isuzu H-Series 4500 5500
19981999 Chevrolet Suburban 2500/GMC Suburban 2500 (option)
19982000 Chevrolet Express 3/4 or 1 ton
19982001 Kodiak/Topkick
19982001 P12 HD Motorhome Chassis. The Workhorse W-20 is a clone of the P12 Chassis
L21/29 share roller cams, intakes, injectors the L21 got sodium filled exhaust valves and other changes for CNG/LPG sustained WOT usage.
The GEN 7 8.1 came next in line for 2001.
peace
Hog
  #20 (permalink)
Old 01-12-2016, 07:56 PM
1997topkick 366 tbi
Hey guys I have a 1997 topkick with a 366 tbi motor, it aint fast but runs fine with the proper amt of maintenance.
  #21 (permalink)
Old 01-12-2016, 08:55 PM
WOW this thread started in 2011 and still going............
396 big block and 427 tall deck balance 85Sierra Engine 10 03-07-2014 07:59 PM
427 TALL DECK block icebreakr1969 Engine 20 10-07-2011 01:01 AM
427 tall deck question tigsmc72 Engine 5 10-04-2011 07:17 PM
BBC tall deck question?? Overdriv Engine 2 07-30-2006 09:47 PM
what is a tall deck block? bigwildgrin Engine 3 06-04-2005 05:58 PM
