BBC Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2002, 01:54 PM
Unhappy BBC Timing
BBC Timing question
Having a problem and looking for technical advice?
I have a 454 +.060 with Accel electronic no vac distributor. I have removed dist. and check setting on dist bench to which it is right on to manufacturer spec 24 degrees total mechanical advice starting at 800 rpm and in by 2800 rpm.
My problem is that I can not get a proper base timing of approximately 12 degrees. I have a solid roller Comp Cam with a good two summer brass distr. gear and a true double roller Comp Cam timing chain set with again two summers time on them. I rebored the cylinders to +.060 and again this year I cant get proper timing ???
I have a Fluid Dampr and have re degreed the cam again to find it right on. When I bring #1 to TDC the pointer lines up with the timing indicator and the distributor rotor is pointing to #1, yet when I put the newly calibrated Snap On timing light I get 45 degrees as a base timing setting??
I cannot get the timing down to even 20 degrees BTC without it ready to stall? I advance the timing by ear and it starts to get lumpy and then I retard the timing and it again starts to get lump and I set it at approximately its best run & start and its at 45 degrees BTC. As I rev it I get an advance of 24 degrees on top of the 45. When I road test it it runs great and I don't hear ANY pinging!
I've been a Tech for many years and and have set many a system. A number of years ago I had the mains line bored and am woundering if the .005 or so thousands that are there would cause this timing situation? The Comp Cam double rooler timing chain set is .005 compensated from factory.
Would appreciate any help on this matter.
1933 Dodge Coupe BBC
1956 Harley Davidson
1991 Chev 454 SS
1987 Monte Carlo
Old 06-02-2002, 07:55 PM
4 Jaw Chuck's Avatar
Post
Hey TR! are you the guy third igloo from the corner?
Anyway, sounds to me like you are reading something incorrectly. If I understand you right you are saying the timing is set at 0 degrees-TDC and the timing gun is telling you it is 45 degrees BTC? The Fluid dampeners are only marked out in 2 degree increments up to 50 degrees BTC, is the timing light saying it is almost off the markings?! This is all very confusing can you give us more info?
— Han Solo
Old 06-03-2002, 02:44 AM
New Member
Post
hello top rod
45 degrees sounds like you have the timeing light hooked to the wrong lead.are you sure you have it hooked to number one ? i'm sure it fires every 90 degrees tho so maybe its not that.also some of those snapon lights are programable but i don't think to 45 degrees....good luck
[ June 03, 2002: Message edited by: HQ Pete ]</p>
Old 06-03-2002, 04:01 PM
Post
Hi 4 Jaw Chuck,
What I'm saying is that when you get your best idle setting timing by ear and it starts A-1 my timing is at 45 degrees BTDC. My Snap-on light has no advance dial and I also tried a different light with same results. I dont think it would run very good let alone idle smooth as it does if it was 45 degrees advanced? I was thinking that maybe I was picking up an electrical field someway. I seperated the #300 Accel wires and still the same.
Is it possible for an engine to start up easily and idle fairly good (cam .652 lift) set with 45 degrees advance?? I dont think so? I think I'm getting a false reading and would like to varify.
If the piston is at TDC and the timing pointer is at 0 degree and the rotor points to number one would the timing not be in proper sync, enough to get your base setting?
Thanks for the help guys, appreciate it.
1991 Chev 454 SS
1987 Monte Carlo
Old 11-13-2007, 11:48 AM
460Stanger's Avatar
Doctor of Enginology
Is it TDC on the COMPRESSION STROKE?
