Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC timing and idle problems
Old 11-10-2012, 07:26 PM
cdminter59 cdminter59 is offline
When you set the crank at 12:00 and the camshaft at 6:00 the #6 piston is firing. You can drop the distributor in and have the rotor pointing to the tower that #6 plug wire is in. You can also rotate the crank 1 revolution and drop the distributor in pointing to the tower that #1 plug wire is in. It is easier to just drop the distributor in with the rotor pointing to #6. Check your timing again, if it is off your balancer may have slipped. Here is an article to read to determine TDC if you suspect the balancer is off. http://www.crankshaftcoalition.com/w...op_dead_center
The Following User Says Thank You to cdminter59 For This Useful Post:
Stubbs82 (11-10-2012)
