bbc tunnel ram question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2009, 03:27 PM
I just picked up a used bbc weiand oval tunnel ram intake that I am using for a dual tbi project. I went to mock up with my distributor and the hole in the intake is larger than the 1.25 gm usually is. The hole is about 1.45. I am wondering if in another life is might have had a mag of some sort. Anyone have an idea. It won't be a problem to make a collar to use it but just wondered..
Thanks
Old 11-01-2009, 04:35 PM
life is a temporary assignment
Mine is the same way.. Once you tighten it down, you shouldn't have a problem..
Tunnel Ram on 383 Stroker Nitromethane Engine 6 02-25-2011 08:06 PM
Tunnel Ram on a sbc jake_arcticcat Engine 23 07-07-2008 02:54 PM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 01:22 PM
Effects of compression ratio on tunnel ram throttle response Adrenaline_Fiend Engine 4 09-10-2003 01:39 PM
Tunnel ram OR NOT ?? ss crazy Engine 11 09-09-2003 09:57 AM
