in 1965 there was a 396-375 hp "Z-16" RPO car. It had the hi rise manifold, holley carb and correct low profile air cleaner and fit under the stock hood.
The 427L-72 L-88 air cleaner is the lowest profile air cleaner. Google search Z-16 396 chevelle. You need the correct 396 oil pan, frame tabs and motor mounts and either the origional Z-16 air cleaner or the corvette 427-425HP L-72 or L-88 air cleaner base. You can still buy these from restoration sources. Remove the carb choke and choke horn or get a HP style center body. www.ramairbox.com. They also have low rise air cleaner bases + ram air systems and components. (if you want "In car" power) |
| lines are off on ss hood for 68 chevelle | SARGE4E | Body - Exterior | 1 | 06-04-2011 05:55 AM |
| 69 chevelle stock hood | ss396si | Hotrodding Basics | 2 | 04-26-2011 06:11 AM |
| Hood pins verse stock hood latch | 62440 | Body - Exterior | 3 | 08-23-2010 09:30 AM |
| Hood pins on a 72 Chevelle | phorce1 | Body - Exterior | 1 | 05-26-2006 09:05 PM |
| Chevelle hood | Scrooge | Body - Exterior | 3 | 07-29-2003 04:00 PM |
