BBC valvetrain issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 08:29 AM
I bought an unfinished project which included a Gen VI 454. It's a marine block, .30 over and has rectangle port heads. I don't know if the heads are original to the engine. It has a Crane flat tappet hydraulic cam with .533 lift on intake & exhaust. It runs strong but has broken 2 exhaust pushrods. When the first happened I thought the adjusting crimp nut came loose. ( It was converted to adjustable rockers). When the second one broke (different cylinder) I pulled everything off and saw that the rockers were contacting the studs at full lift. So I ordered a set of rockers from Summit with extra long slots for high lift cams. When they arrived I compared them to the rockers on the car and the slot is the same length!! I double checked the the part # in the catalog and it's correct. WHAT THE HECK IS GOING ON???
I measured my pushrods and they are standard length. Because of the mix parts could the standard pushrods be to long for this application?? Any thoughts would be appreciated.
Old 07-14-2008, 08:44 PM
If the heads were converted from positive stop to adjustable.it means drilling,taping and installation of new studs.Maybe the studs are misaligned and causing the interference... Or maybe there is a mix of MK Vl block with MK lV heads that use different lenght pushrods...
Old 07-14-2008, 09:03 PM
The rocker stud conversion is a bolt on the rocker studs are 3/8 on the bottom and 7/16 on the top. No drilling required. I am with Fbird grind the rocker to get the clearance you need I used to do it on SBC stuff when I was in high school when I could not afford anything else.
Old 07-15-2008, 05:04 AM
Last journal entry: PICTURE TEST
valve train
I wouldn't grind on any thing until you figure out the problem..
Have you checked the pushrod geometry????
Keith
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
Lowering - Camber issues 49lincoln Suspension - Brakes - Steering 1 05-25-2006 12:24 AM
96 to 00 BBC Question Mustangsaly Engine 6 02-20-2006 07:03 PM
BBC Big Block Questions Mustangsaly Engine 6 01-21-2006 06:59 PM
454 bbc valvetrain wear. what is too much? MuscleBlock81 Engine 8 09-12-2004 12:50 PM
