-   -   BBC vs SBC mount locations & dimensions? (http://www.hotrodders.com/forum/bbc-vs-sbc-mount-locations-dimensions-168089.html)
y5e06 11-08-2009 07:55 AM
I'm looking for specifc info in regards to BBC vs SBC mounting locations.
From what i've read, the engine/frame mounts are interchangeable in as much as BBC engine will fit on the SBC mounts & vice versa.
So, Are the dimensions from the motor mount boses to the rear of the block the same for SBC & BBC? If I swap from a BBC to SBC, using the original mounts and keeping my current TH400 trans, will I have to relocate the trans any? Are the block dimensions the same for these two reference points?
Thanks!
Bryan59EC 11-09-2009 07:31 PM
In a lot of cases--they interchange without issues.
early Chevelles----will bolt up (with the exception of the 307 Frame mounts), but the big block will sit higher than it is supposed to on SBC mounts.
I believe the 73-87 Chev/GMC trucks require a different frame mount as well, but the clamshell is the same.
58-64 Chev full size----a BBC will bolt up on the factory v-8 mounts, but not the 6cyl mounts.
Might help if we knew what you were working on.
y5e06 11-09-2009 09:38 PM
ah, yeah. thanks
454 '86 suburban
Bryan59EC 11-10-2009 06:21 PM
The 454 rubber mounts were different on my 79 from a SBC to a BBC
The rubber mounts are the ones that bolt to the frame-----both sets of holes should be in the frame for these.
You will need to change the exhaust to meet up with the BB.
You will need a LARGE radiator (454 trucks got a 4-row), The BB fan shroud, and fan.
Wiring to the front of the motor may need to be lengthend----I was about 2" short for my alternator wiring.
A 454 Flywheel or Flexplate must be used.
Very straight swap with no issues at all-------did mine in an afternoon, and had the exhaust put in the next day (of course I was much younger and had more energy way back then).
denunger 11-10-2009 07:22 PM
bbc mount
I have dropped bbc in sbc mounts in suburbans/pickups9'73-'87) several times without any problem. I know there are different mounts for big blocks, but????
6426yy 11-17-2009 07:09 AM
I just put a BB in my '83 without changing the mounts. At one time I thought it wouldn't work but I decided to try and voila!
y5e06 11-17-2009 09:33 AM
did the engine position change any between the SBC & BBC when reusing stock mounts?
edit: never mind. that question doesn't make sense since located the same w/ reusing the same mounts!
richard stewart 3rd 11-17-2009 11:10 AM
Hi,
Here are some popular engine dimensions for swapping.
http://www.kabamus.com/garage/motorswap/swapchart.pdf
