BBC vs SBC mount locations & dimensions?
I'm looking for specifc info in regards to BBC vs SBC mounting locations.
From what i've read, the engine/frame mounts are interchangeable in as much as BBC engine will fit on the SBC mounts & vice versa. So, Are the dimensions from the motor mount boses to the rear of the block the same for SBC & BBC? If I swap from a BBC to SBC, using the original mounts and keeping my current TH400 trans, will I have to relocate the trans any? Are the block dimensions the same for these two reference points? Thanks! |
In a lot of cases--they interchange without issues.
early Chevelles----will bolt up (with the exception of the 307 Frame mounts), but the big block will sit higher than it is supposed to on SBC mounts. I believe the 73-87 Chev/GMC trucks require a different frame mount as well, but the clamshell is the same. 58-64 Chev full size----a BBC will bolt up on the factory v-8 mounts, but not the 6cyl mounts. Might help if we knew what you were working on. |
ah, yeah. thanks
454 '86 suburban |
The 454 rubber mounts were different on my 79 from a SBC to a BBC
The rubber mounts are the ones that bolt to the frame-----both sets of holes should be in the frame for these. You will need to change the exhaust to meet up with the BB. You will need a LARGE radiator (454 trucks got a 4-row), The BB fan shroud, and fan. Wiring to the front of the motor may need to be lengthend----I was about 2" short for my alternator wiring. A 454 Flywheel or Flexplate must be used. Very straight swap with no issues at all-------did mine in an afternoon, and had the exhaust put in the next day (of course I was much younger and had more energy way back then). |
bbc mount
I have dropped bbc in sbc mounts in suburbans/pickups9'73-'87) several times without any problem. I know there are different mounts for big blocks, but????
did the engine position change any between the SBC & BBC when reusing stock mounts?
edit: never mind. that question doesn't make sense since located the same w/ reusing the same mounts! |
Hi,
Here are some popular engine dimensions for swapping. http://www.kabamus.com/garage/motorswap/swapchart.pdf |
| low mount alt. bracket for BBC short water pump | uneedmorethen10s | General Rodding Tech | 3 | 01-26-2004 04:41 PM |
| Need insight on SBC / BBC motor mounts | unstable | Engine | 6 | 01-26-2004 07:01 AM |
| bbc and sbc motor mounts again | nosliw721 | Engine | 1 | 10-09-2003 03:19 PM |
| SBC mount bolt sizes | Maverick | Engine | 5 | 11-02-2002 03:16 PM |
| Low mount BBC engine brackets | 41willys | Engine | 4 | 09-18-2002 06:30 AM |
