bbc won't start - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2010, 06:36 AM
bbc won't start
my brother installed a 454 drive train from a 90 sport 454 chev truck into a 70 ss chevelle . everything ran fine for a about a year . just replaced the intake gasket . now we can not start the eng. checked the timming many times piston #2 top comp disturb point strait to it .went got new cap, coil, plugs, wires ? GOT GAS to carb - GOT FIRE to plugs . i dont get it , thing will not hit a lick rockers move so chain good and the darn thing ran fine when he pulled the intake has anyone got any help on things to try thanks
Old 12-03-2010, 12:31 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by clwarters
...piston #2 top comp disturb point strait to it .
Is the "piston #2 top comp" a typo, you mean Piston #1, right?
If you set your initial startup firing to #2, you need to change it and verify everything else, firing order, compression stroke on #1, TDC, etc.
Old 12-03-2010, 02:38 PM
bigdog7373's Avatar
Of course it's fast
Put the #1 cylinder on tdc of the COMPRESSION stroke. Install the dizzy with the rotor facing the #1 post and connect the rest of the wires in the correct order.
Old 12-03-2010, 05:55 PM
bbc
thanks the problem seem to be a ground wire , ahd he put the wrong intake gasket on , running fine now :lol:
Old 12-03-2010, 09:17 PM
bigdog7373's Avatar
Of course it's fast
glad to hear that.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
crank no start meev182 Engine 7 06-17-2007 07:27 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 06:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 05:23 PM
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 06:47 PM
