BC/CC with graphics - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2011, 11:28 AM
BC/CC with graphics
I知 almost ready to paint my 95 Ram. I致e done some research and think I have my plan right, but want to run it by everyone for some input. I知 going to be using PPG BC/CC . The color will be Emerald Green Pearlcoat/ Silver Pearl two tone, plus Silver Pearl ghost flames. The truck will be disassembled for painting, so everything will get the BC/CC.
The truck has been primed with epoxy primer, then high build 2K primer. I plan on blocking using 180, then 400. Then 600 wet.
Painting will consist of a sealer coat, then 2 coats of DBC BC, followed by 2 coats of 2021 clear. The next day, I値l assemble the truck, then wet sand the panels to receive the pearl with 800. The pearl will be Silver Pearl in DBC 500. I値l spray that and then two more coats of clear over the pearl.
I only paint something every 5 years or so, with most of my recent experience being Awlgrip on boats. I have never done a BC/CC system. So I have some questions about the clear.
I would like to do the pearl in the DBC 500 directly over the basecoat. But due to having to BC, then assemble, then mask and paint the pearl, then disassemble to clear coat, then assemble again. I think there痴 less chance of screwing it up by going BC/CC/Assemble/Pearl/CC.
Should I use hardener in the BC and 500?
Are there precautions that I need to take having the 500 between the coats of clear?
Will the 2 additional coats of clear only on the pearled panels be obvious, or should I plan on clearing everything again?
Is 800 the right grit to use for wet sanding between coats of clear?
If I finish the first coats of clear, then decide to do an overnighter, and have the pearl and final clear applied within 12-18 hrs or so, do I need to do the 800 wet sanding?
Is it actually better to wait 24 hrs or more between the first coats of clear and the final ones?
Old 04-23-2011, 04:29 PM
it sounds like you got it all pretty much covered just follow the directions on the can if you have any problems figuring it out then you can get the p sheet for it. you should be able to get away with re-clearing the other panels just as long as you get your texture right but if you wet sand with a soft block and buff youll be in good shape. ive always been told to use 600 in-between clears. it sounds like a good color scheme though
hot rod graphics Jokersrage Introduce Yourself 12 02-22-2006 10:35 PM
basecoat, graphics, clear, how do you get around the timing while doing the graphics? GMW Body - Exterior 5 01-22-2006 04:58 PM
Honda graphics jcclark Hot Rod Art 0 11-14-2005 10:36 AM
Looking For The Right Car Graphics drm184 Hot Rod Art 6 09-26-2005 10:36 PM
Graphics PAS55 Body - Exterior 3 09-30-2003 08:47 AM
