Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bc/cc help please
Old 08-22-2012, 08:59 AM
MARTINSR MARTINSR is offline
If there is no hardener in the base on your first application and you have sanded thru the clear there is a good possibility you will have lifting. You are going to need to seal off those sanded thru spots with primer. And you can't apply the primer real wet either, or that will wrinkle or lift as well.
Spray it light, make sure it's warm, use the faster reducer, anything to keep those solvents from soaking in and going under the clear to wrinkle it.
