Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bc/cc help please
Old 08-22-2012, 01:01 PM
lifted08sierra lifted08sierra is offline
thank you very much for the replies. The base has no hardener. I do have a white epoxy primer and was told that it was junk so we didnt use it the first time around. Ive been told if i thin the epoxy a little bit 4:1:1/2 it will lay nicer. Dont want to run into issues with epoxy as its not suppose to be sanded. Also was thinking about using it now to seal/seperate whats going to be on top, and whats their now. However I imagine i could run into some big issues with lifting from the solvents under neath. How long would you guys recommend before getting back at this? I was consiidering pulling the car back in his garage and letting my salamander run all day, even though it is 80-85 degrees as it is. Thanks Alot!
