BC/CC over SS Urethane. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2011, 02:18 PM
It has been asked if it’s possible to repaint bc/cc over ss urethane without any adverse effects. The answer is yes. You can also repair and blend when needed. I did just that recently on 71 Fiat for a customer.
As mentioned above this car was painted previously with ss urethane. Nobody wanted to do it for him without repainting the whole car because they couldn’t match the color. Nobody knows the paint code that had been used. He came referred to me because a previous customer went through the same thing and I was the only one that around that would do it. I like to eat.
I called my jobber and had him come down to the shop with his camera thingy and do his thing. After he did his thing back at the store and came up with a code I had him return to my shop with alternate chips to the GM code he gave me so I could do my thing. Verify the color match.
Here’s how the car was delivered to me:
All he wanted was some fiberglass cracks fixed and few other defects corrected. Yes it is a fiberglass body.
Old 01-11-2011, 02:50 PM
cyclopsblown34's Avatar
Colorsanding painter
What the heck model is that? I thought Spider then you said it has a fiberglass body.
Old 01-11-2011, 02:55 PM
Ferrara, If I spelled it correctly. Yeah, it threw me off too when it first came in with the cracks by the hood corners. Thought I was going to do some welding.
Old 01-11-2011, 03:00 PM
It just might be the sexiest Fiat I've ever seen. The paint work looks great too.
Old 01-11-2011, 03:07 PM
Thanks for the compliment. Owners very happy with it too. Maybe if he finds a hardtop for it I'll get that job,also.
Old 01-11-2011, 08:24 PM
Slick work!
No drips, no runs, no errors.
Super paint job.
Old 01-11-2011, 11:01 PM
Commanderkewl's Avatar
Time traveler stuck here...
I'm impressed, ya wanna come to warmer climate and paint mine?
Sorry it's old steel tho..
Old 01-11-2011, 11:26 PM
Don't tempt me. Work is scarce here.
Old 01-12-2011, 09:07 AM
Underground's Avatar
Last journal entry: 54
Looks great, but what about the difference in looks between the cleared fender and single staged door? You can tell when a car (or part of a car) has been cleared. Did he just live with it or was he one of those customers that don't notice these things?
Old 01-12-2011, 12:32 PM
Valid question. What I see and other techs pickup on the visual differences isn’t what the average person can pick up. I can see it, but the customer doesn’t. We as techs can beat ourselves up over nothing in everything we do and the customer hasn’t a clue to why we’re so disappointed with our own work.
Additionally, as I mentioned previously that body is fiberglass with none of the manufacturing flaws corrected. Moreover, whoever painted the car previously didn’t feather their work properly so you can see their flaws further making the differences unnoticeable.
With all that I guess he can live with it comfortly.
Old 01-12-2011, 04:22 PM
what did you use to feather edge the hard tape lines on the primer you sprayed?
Old 01-12-2011, 04:57 PM
if you look close, you see his paper looped over itself. This leaves an edge that is not as hard as it looks.
Old 01-12-2011, 05:33 PM
yea but do you do a wet on wet basecoat right over those lines, or do you still sand and/or scuff as well?
Old 01-12-2011, 05:38 PM
I was wondering when someone was going to ask that question.
First, there are no hard tape lines. It’s hard to see; but, if you look closely the paper is rolled back creating a soft edge that’s easier to feather edge. Prior to papering I use a red scratch pad to scuff the area around where I’m going to primer. Using this technique keeps my work areas to a minimum so I don’t have to base larger areas than needed thus saving material or at least stretching the materials I use. Yeah, I’m cheap with paint, but neat.
After removing the paper I blocked the primered areas with 320, then went to 800, then finished scuffing all areas to be painted with a gray scuffpad. His is my normal procedure. Nothing fancy, just straightforward.
Additionally, this is a tricky color. If I tried to blend that color with the color primer you see I would have been presenting pictures of a poor color blend than those pictured. No matter how much paint I used the gray primer would have presented a darker contrast through the basecoat. Therefore, white sealer as recommended was used; although, not pictured. Base purchased was only an eight of a pint.
Old 01-12-2011, 09:12 PM
milo's Avatar
point on positive
white sure does make the best ground for red , nice clean project , thanks for the pictures
keeping it a hobby
ss urethane or bc/cc vintage guy Body - Exterior 5 03-30-2007 02:39 PM
SS Urethane jcclark Body - Exterior 5 05-19-2006 05:02 AM
Urethane On Wood jcclark Body - Exterior 36 10-28-2005 01:21 PM
2k urethane richamer1 Body - Exterior 4 06-16-2005 04:50 AM
When to wax Urethane 68Camaro396/375 Body - Exterior 3 06-06-2005 09:48 PM
