Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bead blast guns and nozzles
Old 11-16-2005, 09:23 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Does anyone have information relating to the size and placement relationship of the air jet to the suction tube to the media nozzle in a bead blast gun. Is there a difference in nozzle size for different size or type of media. Also wondering about the air requirements for the different size nozzles. My compressor size isn't an issue, I just would like the info. I recently aquired a big blast cabinet (it needs some pieces to make it work) and I found some industrial blast nozzles that need rebuilding. I tried contacting the manufacturer of this unit but it is a high end industrial unit and they want a fortune for replacement parts. Thanks for reading this.
BE different....ACT normal.
