Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bead blast guns and nozzles
Old 11-18-2005, 09:03 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Ok I feel like some kind of troll replying to my own thread, but I have found out a couple of things and thought I would add to it. The air jet is usually 1/2 the size of the media nozzle. If you have a gun with a .094" air jet it will take a .188" media nozzle. The air jet in a cheap gun is located behind the suction port. I have a gun that has a tapered tube that puts the air jet opening forward of the suction port. That one has a .200" air jet so I would surmise that it should have a .400" media nozzle. The solid carbide nozzle that was in it was worn out to over 1/2 ". I wonder what you should be blasting with that one. I still would like to know what are the proper air pressures and which type of media works best with the various size orifices. Thanks for reading this.
BE different....ACT normal.
