Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bear claw latch with stock outside door handles
Old 07-14-2011, 01:20 PM
Irelands child's Avatar
Irelands child Irelands child is offline
Those bear claw latches don't have to go in the exact same position as the OEM's. You can mount them lower and run a bell crank and rods to the handles. While I don't have the outside handles, ran mine with that bell crank and a pair of rods and a return spring. As far as the exterior paint - well, you'll have to be careful, but you will have to repaint the door jambs:
Shows the rods and an electric actuator that is now been replaced by a spring 'hanger'
Upside down
Shows the door release
I also have a suicide door safety pin as the mini bear claw latches while much better then the original latch still have only a single rotor.
Not a job for the faint of heart, as I ended up using a circle saw and adding a couple of access holes to the inner door panel - see the brighter red rattle can primer. You also might consider adding some reinforcing to the body at the door striker - that metal is puny at best
Dave W
Irelands child
