Bear claw latch with stock outside door handles - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2011, 08:44 PM
I have a 30 model A Roadster and am thinking about installing the mini bear claw latches in it this winter. This car has stock interior and exterior door handles. Is there a way to keep (especially) the outside handles and make them functional with bear claw latches? I know that a car without windows that I could reach inside to open,but then what do I do about the outside handles---can't shave,the car is already painted
Old 07-14-2011, 12:20 AM
471A
I have a 29 Tudor with stock exterior door handles and mini bear claws. I will recruit my tech-savvy daughter to take digital photos and, assuming that is possible with this website, post the photos of how this was done. Inside the car, the "door handle" is a simple straight rod that slides up and down to open and close.
Old 07-14-2011, 05:47 AM
That would be great
Thanks
Old 07-14-2011, 10:25 AM
471A
All of the attached photos depict the 29 Tudor passenger side door. Driver's side installation is the same. Ignore the duct tape.......
Old 07-14-2011, 10:30 AM
471A
See attached photos
Attached photos
ID:	56843   Click image for larger version
ID:	56844   Click image for larger version
ID:	56845   Click image for larger version
ID:	56846   Click image for larger version
Old 07-14-2011, 11:09 AM
Attached photos
Thank you,did your door always have the raised portion,or did you have to do that to accommodate the new latches?
Old 07-14-2011, 11:51 AM
471A
The raised portion was fabricated to make room for the latching mechanism.
Old 07-14-2011, 01:20 PM
Irelands child's Avatar
Those bear claw latches don't have to go in the exact same position as the OEM's. You can mount them lower and run a bell crank and rods to the handles. While I don't have the outside handles, ran mine with that bell crank and a pair of rods and a return spring. As far as the exterior paint - well, you'll have to be careful, but you will have to repaint the door jambs:
Shows the rods and an electric actuator that is now been replaced by a spring 'hanger'
Upside down
Shows the door release
I also have a suicide door safety pin as the mini bear claw latches while much better then the original latch still have only a single rotor.
Not a job for the faint of heart, as I ended up using a circle saw and adding a couple of access holes to the inner door panel - see the brighter red rattle can primer. You also might consider adding some reinforcing to the body at the door striker - that metal is puny at best
Dave W
Old 07-15-2011, 09:09 AM
Thanks
The body is already reinforced all the way down the door jamb,so I'm OK there
Never changed my Avatar---don't have the Model T anymore this is the new one
Bear Claw Latch Installation using Stock Door Handles kbuhagiar Body - Exterior 9 06-08-2011 06:52 AM
Door Latch Installation using Stock Handles kbuhagiar General Rodding Tech 3 04-27-2011 11:55 AM
Bear Claw latch Babyburr General Rodding Tech 2 11-19-2009 10:37 AM
Bear Claw Latch Install hotrodjim58 Body - Exterior 8 03-06-2008 05:07 PM
