bear claw latches - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2007, 02:21 PM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
bear claw latches
does anyone know if the 60lb solenoids can go in place of the 35lb on bear claw door latches. electric life brand.
Old 10-04-2007, 02:43 PM
powerrodsmike's Avatar
Wiki Edits: 161
If you adjust the solenoid so it isn't ripping on the lever too hard at the bottom there should be no reason why you can't use the 60# ones.
Usually though, if you need 60# solenoids on a bear claw latch to get it to open, there may be alignment/ adjustment issues or the door seal pressure is too high or the latch and striker may just need lubrication.
Some spray white grease on the inside of the latch and some wax lube stick such as "door eze" on the striker works wonders.
Later, mikey
BE different....ACT normal.
Old 10-04-2007, 03:12 PM
i just put on new weatherstripping because the old was dried up. and the new weatherstripping is a bit thicker. ive fused with the alignment so much its good as its gonna get. and i have used a bit of grease and that helped out a bit.
Old 10-04-2007, 06:38 PM
Wiki Edits: 161
Get some wax paper and shut it in the door between the new weatherstrip and the door. leave it for a while in the sun if you can, That will give a waxed (slippery) coating to the weatherstrip and help the door open and close better until the new weatherstrip gets formed to it's installation.
Also, try loosening up the cable that goes from the latch to the solenoid just a little bit. The plunger type solenoids work better with as much slack as they can get. Don't loosen it too much that it cant disengage the latch at the plungers lowest point though...
When you give the cable some slack, the plunger acts like a hammer with a longer swing, getting more speed to hit the latch lever with. If the cable is too tight, the plunger never develops any speed before it can disengage the latch.
Later, mikey
Old 10-04-2007, 08:13 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have those solenoids on the 59 (big ol heavy door) with stock latches.
Mikey is right in telling you they want some slack in the cable.
But, you don't want them overpulling the latch either.
Bryan
Old 10-04-2007, 09:13 PM
its gonna be overcast weather here for the next couple of days but ill try the wax paper when its sunny out. or could i do somethin like armor all??? i ordered the 60lbs solenoids today so they will be here monday or tuesday. so when i install them i want just a bit of slack.
right now i cant adjust anything with the solenoid because its the bear claw that comes with a solenoid already attached and there is no adjustment.
im just hoping that the 60lbs will work. im sure they will but i still have my doubts.
Old 10-04-2007, 09:53 PM
Wiki Edits: 161
When you push the button on a 60# it sounds like you threw a baseball at the door......THA-WUNKKK!!!!
It'll pull it.
Later, mikey
Old 10-04-2007, 11:30 PM
ok i belive you.
btw i just had an image in my head of me hitting my door with a bat to get it to open lol. idk if any of you think thats funny but it put a big smile on my face
Bear Claw Installation - 1954 Chevy Truck Houston54 Body - Exterior 17 07-03-2009 10:56 AM
installing bear claw latches oldguy829 Body - Exterior 20 11-27-2007 07:30 AM
Bear Claw Latches old40ford Body - Exterior 1 08-18-2006 03:28 PM
Bear claw door latches 1931 steve Body - Exterior 8 12-13-2005 05:01 PM
bear claw latches for suicide doors 54chevy22 Body - Exterior 2 09-11-2005 05:19 PM
