Bear claw latches on a model A - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2012, 07:13 AM
31 five window
Last journal entry: grill and rear end
I made my hinges now I need latches.The doors on my model A coupe are thin and not much space between the inside and the window channel.Has anybody done this and what did you use? Thanks for any info.
Old 11-02-2012, 07:41 AM
Last journal entry: 27
i used the small bearclaws.
i had to fab up some linkages but it was very hard.
Old 11-02-2012, 09:22 AM
302 Z28's Avatar
One tip is don't scrimp on price. There are bear claw latches then there are bear claw latches.
Buyer beware
Vince
Old 11-02-2012, 09:26 AM
31 five window
Thanks to both. I know I saw bear claw and bear jaw in Speedway. I figure the bear jaw are cheap knock offs. Am I right?
Old 11-02-2012, 09:32 AM
31 five window
How did you fit them between the window channel and the inside of the door. The measurements advertised seem to be too wide unless you widen the door?Any pics?
Old 11-02-2012, 10:39 AM
Irelands child's Avatar
You need to use the small single rotor bear claws. Mine for the '31 roadster came from Rocky Hinge. It takes some work along with their 'installation kit' but are worth the effort.
I had to hole saw some additional access holes too. That door opening solenoid is gone as well:
The latch levers (Watson's Street Works) and the 'suicide door' pins (Juliano's) - used because they are single rotor latches:
Dave W
Irelands child
Old 11-02-2012, 10:41 AM
302 Z28's Avatar
IMHO Rocky Hinge is one of the primo bear claw latches.
Vince
Old 11-02-2012, 11:08 AM
i typed that before i was awake all the way
imeant to say it WASNT very hard.
they went to the inside of the channel on my 27 chevy (towards the cars interior)
it has thin doors.
Old 11-02-2012, 01:33 PM
31 five window
Dave W
Thanks,but you have a roadster with no windows. My problem is according to the measurements advertised they are wider than the distance between my window channel and the inside of the door.But I will check on the ones you recommended.
Old 11-02-2012, 01:36 PM
31 five window
it has thin doors.
Thanks,I know the install will not be hard if I have enough space. I don't know if your Chevy doors are thicker than mine.
Old 11-02-2012, 02:04 PM
31 five window
Thanks Irelands child. I just went to Watson street works site and they just came out with smaller ones just for Model A's and VW's.I think they will be what I need. I saw similar ones in Speedway but they didn't say anything about being rated for 750 Lbs like watsons.I don't want my wife falling out of my car when I make a hard turn.
Bear claw Latches chief36chevy Body - Exterior 2 02-21-2011 03:14 PM
electric bear claw latches fivewindowcoupe General Rodding Tech 5 12-16-2008 07:23 PM
bear claw latches 35 ford General Rodding Tech 3 10-04-2008 08:01 PM
bear claw latches elcaminodragster General Rodding Tech 7 10-05-2007 12:30 AM
Bear Claw Latches old40ford Body - Exterior 1 08-18-2006 04:28 PM
